Old 08-21-2007, 07:38 PM   #3
supradaddy0803
supradaddy0803's Avatar
The turbos being oil cooled really wouldnt heat it up that quick and cool off that quick. Did you use the radiator temp sensor or did you wire it out of the system. Mine isnt connected and the fan runs full blast all the time. other than that check to see if your thermostat is working properly and yes I know it sucks to get to. Also try disconnecting the plug for the temp sensor in the radiator and run it down the road then if it doesnt do it then just leave it disconnected.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
