Old 08-21-2007, 10:06 AM   #1
supradaddy0803
supradaddy0803's Avatar
That is the factory Blow off valve. Its all there all the vaccum piping is metal and underneath. As for needing it I have plugged mine off and gotten a aftermarket one because the factory ones are known to leak. As for the warm up how much warmer is it getting mine stays a constant through all driveing ranges and are you still running the stock hydro fan or a electric?
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
