Old 08-21-2007, 12:09 AM   #1
supradaddy0803
supradaddy0803's Avatar
Check your ignition timing sounds like it is a bit off. If not that I would check the TPS ( throttle postion sensor) to make sure it is rigged right. But I am thinking it is your timing.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
