Old 08-17-2007, 03:49 AM   #1
ethan12510
ethan12510 is on a distinguished road
Originally Posted by Isphius
The light flashes when the speedo cable broke. Grinding could be a wheel bearing or a bent/dented shock. No idea on the targa seals. The low oil pressure is cause either your pump is starting to go, or your bearings are worn out. Although my n/a was at 0 at times and went up to almost 40 going down the highway, And it ran fine. Check your oil also. And its a good idea just to pull a diagnostic anyways.
does the check engine light come on when ur car is thowing a code? or will it show problems when the light is not on?
ethan12510 is offline   Reply With Quote
