Thread: engine swap !
Old 08-10-2007, 07:21 PM   #11
Knightryder
Knightryder's Avatar
Knightryder is on a distinguished road
Default TQ vs HP
Originally Posted by Isphius
Torque doesnt always necesarily make a car faster, But it does feel nice. Its good to have about the same tq/hp. Buttt, you want the torque down low, before the hps kick in. A 1j that did have the same torque via boost, would make it at a higher rpm than a larger motor, which is no fun. For the tq thing....think of how fast a tractor trailer is with and without a trailer. They make like 2500 lb ft of torque, not to sure on them, but its high. And they are hardly any faster with no tralier because they only have about 350 hp. Now stick a motor with even 1000 hp and 2500 lb-ft of torque in there, And...fast ass truck. And it can still tow a tralier.
Actually it is more like 400 hp and 3000 ft lbs of TQ but what you arent taking into effect is gear ratio. I drive a truck for a living, and they are quicker without a trailer because of the power to weight ratio, where a 1000 hp engine isnt going to do anything more than my 400hp engine because it is all about the TQ in a semi. The gears are set for low end torque, not top end hp or speed. That is the worst analogy I have ever seen on the HP vs TQ. All that 1000Hp would do is allow me to keep my speed on mountain climbs. All TQ is is the ability for a vehicle to propel itself foward, HP is there to make TQ. 1 hp is the ability to move appox. 500+ lbs. To much tq is just as bad as to much HP. it is all about balance. The more torque you have the faster you will accelerate, the more HP you have the higher your speed will be. 3000 ft lbs of tq and 400 hp will give you a top speed of about 110mph, where 1000hp and 1200 ft lbs of tq will put you over 200mph. All about balance. And 10,000 hp and 100 ft lbs of tq get you a high top speed but 2 weeks to get there.
Knightryder is offline   Reply With Quote
