Old 08-03-2007, 06:18 PM   #2
SupraDupra
SupraDupra's Avatar
The little yellow box is connected to the harness that powers your tailights. Moisture gets in there and messes it up. Mine is bad too ,but as long as the tailights keep working I'm ignoring the problem. Not sure where to get the replacement ,but if you pop the access panel off from behind the drivers side light you should see it in there.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
