Thread: Optimal Size
Old 06-30-2007, 12:39 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by JPDsupra
What is the best size for a wheels on a supra mk4 not width size just diameter and what would be a good wheels and tires combo for it? The guy at the shop said I should stay as close as possible to stock because the car will ride better and I wont have any problem with retuning the speedometer.
I was thinking about getting these:
They are VR1's from http://www.forgeline.com/wheels/vr1.html and they come in 18x11 and 18x13 and a relatively light and a bit expensive
Whoa. You know a 13" wide rim won't work unless you're running a widebody, or at least flares, right?
Fwiw, I generally agree with the advice you got the guy at that shop. If the offsets on those rims are correct, and you have flares or widebody, those rims are a good combo for the jza80 chassis.
Life begins at 30psi.
