Thread: vandalized
Old 06-22-2007, 06:04 PM   #16
supradaddy0803
supradaddy0803's Avatar
You know it is more funny to watch a car that has a cupped watermelon rind under the drive tires it will never wear through it and just sit there and spin and spin good for like a thousand laughs. Problem with the rachetballs thing is that they float, where does the fuel pump pull from not, the top the bottom yes. A small ball bearing that is big enough to fit in the gas hole does the trick, done it many times send mechanics to scrathing their heads. Most of the time they knew I knew about car stuff and they would try to have me fix it. Another funny one is to take a tractor tire filler, the one that puts water in the tires and fill all of the tires full the guy will get whiplash when he drives. Marbles in the gas tank is funny doesnt do much but when you take off you will here a rolling sound then when you stop you will hear rolling sound hard to diagnose and he will have it in the shop trying to fix it. Or reverse his plug wires missfires are really funny flames out the intake. Or to the cue de graw take all of his lug nuts off except one on each wheel and eventually they will fall off. I dont recommend any of these if you wanna stay out of trouble because I never said this lol.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
