Old 06-08-2007, 09:32 PM   #2
Fkatz
Fkatz is on a distinguished road
hey thanks for the reply i've been doing a lot of searchin around on the internet and read that the bolt pattern for the w58 and the r154 are the same, just that the bolt pattern for flywheel is different. i also read that the clutch will fit on the otherflywheel and if i want to use the w58 i have to use the clutch for it not the turbo one. I know that the w58 is weak but i need to use that 300 clutch, i really don't care if the trans blows up in a couple months as long as i fry the clutch so i can feel better about losing 300 dollars. Thanks and do u know anywere i can get a 7mgte motor w/ecu and wire harness or should i finish the rebuild of my bullshit 5mge and turbo it.
Fkatz is offline   Reply With Quote
