Old 06-08-2007, 05:18 AM   #1
hangsupra
Originally Posted by Fkatz
whats going on everyone just bought a 1985 supra and i love it but had lots of problems and just got a new problem. I rebuilt the whole top end of my motor all new gaskets everything then took it around the block and my clutch was burnt so i bought a 300 centerforce clutch. Took it around the block got a rod knock. Put some bearings in it drove it home rod knock came back. I originally wanted a 2jzgte swap but i work for my father at his repair shop and he told me we'll drive the car around for a little then put the 2jz into it but now i'm really pissed off cuz i spent 1500 total w/buying the car or more i don't know don't want to think about it really cuz i'm broke. But was reading that i could put a 7mgte in w/out motor mount modification and would be realively easy. I want to use my centerforce THREEHUNDREDDOLLAR clutch for at least a year not just two trips around the block so will the flexplate off a 5mge fit the 7mgte bolt pattern wise. any help appreciated if you want to just post that i am a dumbass please go ahead. just would like some1 to brighten my day and say hey u can put a 7mgte in it and use that clutch then i won't feel so bad.
i havent try to use the 7mgte flexplate so i'm ot sure
but the 7mge and the 5mge are the same i know that
because i done it before...
about the 7mgte drop down on the mk2...
yes.... it will bolt up... no modification... but the you gonna use the 7mgte tranny tho... you cannt use the 7mge tranny... because the tranny housing is diff.. one is bigger and one is smaller... and maybe you gonna change the rear drive line too...
fix me up if i'm wrong people
