Old 06-07-2007, 09:05 PM   #1
IHateHacks
IHateHacks's Avatar
Any decent machine shop will take a head with the cams still bolted in even with the cam gears still on. They will take all of it off so, like stated, the valves will be closed allowing for the sealing surface to get cut. They will replace the cam seals, torque all the caps to spec and make sure they get installed into their original order.
I would just take the head as is to a good machine shop and have them figure it out, they will let you know if you need a new head or not, my guess would be the head is fine.
