Originally Posted by supradaddy0803
I used to be a jet engine mechanic for a living. I would say that for the rebuild kit if it includes a new compressor wheel then your trimmed compressor wheel would have to be saved or get the new one trimmed as well. As for the nut I dont think they make a 18pt or 24pt socket or nut but it might be 12pt. Jet engines are a lot like turbos in a sense and they use a ton of 12pt nuts everywhere. Easier to torque and that kind of stuff. Go to sears and get a set of metric 12pt sockets. If they dont fit may be a SAE never know they are funny sometimes.
thx for the reply. I can tell you for sure its not a 12pt on the compressor wheel. The exhaust turbine is a 12pt 15mm. But the compressor nut has waaay more pt's on it than 12. Im pretty sure someone mentioned it could be an SST from toyo. Although they also said this is what the original nut would be like, not a trimmed up wheel nut. Maybe they resused the original, if they did there goddamn retarded.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
