Thread: wish me luck.
Old 05-07-2007, 07:50 AM   #3
west_side_supra
west_side_supra's Avatar
ok lets see here
1st run
dial...
r/t... .697
60'... 2.297
330 ... 5.256
1/8 ... .000 < id didnt read it for some reason
MPH ? same deal
1000' 12.273
1/4 ... 14.614
MPH ... 96.77
2nd run
dial ...
r/t .721
60' ... 1.761
330 .. 5.405
1/8 ... 8.547
mph ... 80.02
1000 ... 11.332
1/4 ... 13.443
mph ... 101.10
3rd run
dial ... 13.50
r/t ... .453
60' ... 1.483
330 ... 4.742
1/8 ... 7.639
mph ... 83.42
1000 ... 9.332
1/4 ... 11.326
mph ... 97.10 mph
you dont have to believe me but i swear to god i aint bull shittin you, my best guess is for the 11sec run was that the test pipe busted on me so it was runnin right off the 3inch dp. the turbo was hittin fuel cut the 2nd run. thats probably why it came to a 13, then rule that with the shitty r/t, and also the 3rd run i warmed them tires up. but ill try to find a way to get these time sheets or photo taken i dont know ill find something so you guys will believe me
7MGTE - 500hp never dyno'd
fidenza cam gears
