Thread: wish me luck.
Old 05-06-2007, 08:26 PM   #1
west_side_supra
west_side_supra's Avatar
id scan the slips if i had a scanner, but the 2nd one i lost because of dial in times the 3rd run i dont think i was even spose to go on the track again but i did anyways. i was also on the 2nd run hittin fuel cut like a crazy man. wwwaaaaa pop waa waa pop waaaaaaaaaaaaaaaaaaa
modifications:
ACT lightweight flywheel
aluminium driveshaft
6 puck 4 sprung clutch and stage 3 pressure plate
shimmed wastegate doing about 11-12psi
hks ssqv bov
no air filter just for that day.
3inch defcon DP
3inch test pipe
all the way back to a 3inch muffler with a silencer because the car is to loud anyways
toyo proxie 4's
adr m-sport
we also removed all the stero equipment i had a box that weighed about 50 pounds in the back then also took out the spare tire passenger seat, and back seat. and again the 1st run the welds on the test pipe broke, i get that fixed today, so i was running it right off the DP.
7MGTE - 500hp never dyno'd
fidenza cam gears
