Old 04-02-2007, 10:43 PM   #2
dannydavi
dannydavi's Avatar
thanks alot man, im going to go and try to get all the parts i need from the many pick n pulls around me, so just grabbing those things off any mkIII supra will be fine then huh? even the flywheel and pedals and everything else i need or might those vary?
clutch pedal
brake pedal
clutch master cylinder
clutch slave cylinder
manual driveshaft
manual gearbox
manual bellhousing to fit your engine
clutch kit to suit whatever gearbox you have
clutch line to go between the master and slave cylinders
driveshafts and prop shafts
anything else you guys can think of or is this all? thanks in advace
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
