Old 03-24-2007, 04:02 PM   #2
D_Train
D_Train is on a distinguished road
Originally Posted by tone loc
check your fuses first then for the tail light you open the hatch and there is a access panel that goes with the tail light. then you will see a white thing that holds all of the tail light bulbs and you just pull that off. if the light bulb is black then its out.
for the fog lights there is one screw that you take off and then you will be able to take off the lamp. pull the black rubber thing back and you will see some wires. disconnect the wires and there is like a pin thing holding the bulb in the lamp. undo that and check if the bulb is out. putting the light back on is a bitch but if you look were the lamp was there is two wires the longer one attachs to a prong on the lamp itself and the other is were you connect the bulb to.
Thanks for the walk through! I'm heading to the auto parts store later today after work! I'll keep you posted!
D_Train is offline   Reply With Quote
