Old 02-09-2007, 07:49 AM   #1
mrnickleye
mrnickleye's Avatar
On mine, with everything tight and new and NO exhaust leaks, I can sometimes smell exhaust.
Sometimes you will get some fuel that has more sulfur in it than at other times. The cat will cause it to burn and smell bad, especially on the de-cel (letting off the throttle).
Also......
My seal on the back hatch is torn along the bottom, with some cracks. Its right where it will get damaged from putting things into the trunk, like luggage, so prbably lots of supras have this problem.
I know that's where it comes in at.
The seal is about $65 at dealer.
On mine, the rest of it is good, and rain does not enter, so I just don't spend the $$
If the heater/ac is on with the fan, and outside air coming in (not recirc), it will keep the smell from coming in because the cabin is pressurized.
