Old 02-07-2007, 07:32 PM   #1
scruffboy
scruffboy's Avatar
Default Your right
The TSRM pics suck at showing the lever and stop. I tried taking a picture but my photogrophy skills leave a lot to be desired. I'll try to explain it, if I can. On the NA, behind the throttle body you will find the "linkage", the cable that pulls when you step on the accelerator. With your car running (and in neutral, of course), pull the linkage to rev the engine. You will see a lever pull back, and a space open between it and a small rod with a rubber boot on it. Let go of the linkage and they will come back together closing the space. Hope that helps. If anyone else would like to add to this, feel free, as I am not an expert.
Scruffboy
