Old 01-09-2007, 06:41 PM   #1
johnkarl
johnkarl is on a distinguished road
Thumbs down doors on upside down
Originally Posted by mrnickleye
Now ask yourself this: will a car run "properly" if the doors are put on upside down??
And........If the transmission is mounted backwards, can I just reverse the shift pattern to drive "properly" ??
Same answer for the vacuum lines routing.
if i was stupid enough to buy a car with the doors on upside down ,the last thing i would be worried about was if it ran ok , although if you can fix the doors on upside down ,i would doubt if it would stop the engine from running ok ,as for putting the transmission on the wrong way, again if it can be done ,obviously you being so cleaver you, and only you, might be able to do this, i still doubt if this would stop the engine from running well ,thanks for your help on this one and look NOT FORWARD to hearing from you in the future, all i wanted to know was in what way would it affect the running of the engine ,not sarcasm from someone like you
johnkarl is offline
