Originally Posted by jeepkaiser65
put it on jack stands
The steel belts in the tires can take on a "set"(flat spot), and then when you start driving it again, you will get a belt seperation. Been there, done that ! Many motor homes and trailers get this from sitting too long.
If you drive the car once a week, it should not happen, as you will park in a different place on the tires.
Plus running it on stands, or once a week drive, the oils in the diff, tranny, p/s, and engine will get spread around and keep moisure from rusting and corroding things.
