Old 11-04-2006, 02:17 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
is it -4 inhg?
if so you have an intake leak... so your air that you're pulling in is going out before the combustion chambers
(tech tip: it's not the compressor on the turbo that makes boost, it's the combusted gasses hitting the turbine that make boost )
you should hear it wooshing tho and normally it would raise the idle
do a diagnostic and check the codes if you haven't done so already
Pics of my build.
Do a diagnostic first!
