Old 10-24-2006, 06:22 PM   #6
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Originally Posted by suprra_girl
there are two knock sensors on your block
they are located on the intake side
one is between about #2 & #3 cylinder, if you stick your arm under there (when it's cold) you'll be able to feel it
the other one is about #5 & #6 right before the starter motor
more than likely you have a broken wire and you just need to repair it
is there a wire on the knck sensor thats close to the firewall
whitequasimodo is offline   Reply With Quote
