Old 10-10-2006, 05:56 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
auto or manual?
there are two bolts at the top behind the head, you can get to them with a little bit of mucking around with 2 14mm spanners, use the 2nd spanner as leverage
of course i gather you have the starter motor out?
don't forget down the bottom you also have the brackets which bolt from the block to the tranny
8 bolts total you need to undo the separate the bellhousing from the block
if you are automatic then you'll need to undo the 6 torque converter bolts as well
good luck
Pics of my build.
Do a diagnostic first!
