Old 10-05-2006, 08:15 PM   #1
tone loc
tone loc's Avatar
to remove the throttle body you have to disconnect all the hoses and the big water hose and all that crap. Then you have to remove the 4 braket bolts which are 2 are were the air intake hose connects and the other 2 are like kinda centered on either side of the pipe(cant really miss them)then there are 6 bolts that connect the throttle body to manifold. For the throttle there is like a 10 or 12 mm bolt and then you should be able to remove the throttle body. i never took the intake manifold off so thats for you to find out.(shound't be to hard) the intake manifold bolts and throttle body bolts are a little tricky to get to so try using diffrent sized rachtes and extensions it should take you tops like hour if its your first time doing it.
