Thread: Code 25 and 26
Old 10-05-2006, 07:13 PM   #2
f00g00
What I did with my injectors while they were out was to power them open and use a can of carb cleaner while they were open to clean them out. You just have to take a spare plug with a couple of feet of wire and hook them up to a battery to energize the injector open. For the carb cleaner use the kind that has the straw and wrap a little tape on it so it seals at the injector opening and spray till it comes out in a good pattern, usually only takes a few seconds. And by al means use goggles when you do this so you don't get any in your eyes!
Also a faulty ox sensor might cause this too.
