Old 10-05-2006, 10:10 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
you have 3 options
buy a replacement 7m and hope it's a good motor
buy a replacement 7m and rebuild it
buy a replacement 7m and at least do the head gasket
it is more than likely rod knock
generally caused by engine running out of oil or possibly previous bhg and water got mixed in with the oil
or less common, oil pickup mesh/pump in the oil pan got jacked on, broken, then metal shards in your oil which then flogged out your rod bearings
good luck with the new motor (it may still be possible to rebuild yours but you will more than likely need another crank as yours may have taken a hiding)
Pics of my build.
Do a diagnostic first!
