Old 10-03-2006, 12:00 AM   #1
Murd
Originally Posted by ravenmaster
Hmmm true however TEMS is a smart system. Automatic adjustment without the need for manual and from what I can see (believe it or not) it would actually be cheaper than the coil overs with the maual adjustment module. Plus for some reason I like stock upgrades when it comes to how it looks. (This isn't really a performance upgrade so much as it is becuase I love my Supra and it should have come with all the premium stuff to begin with). I think the strus are the same as the NON TEMS ones I thinnk it is more the absorbers.....I dunno, i have still been looking but have anyone found any place online for instruction to this, or found anywhere online to order the wing? Thanks for the response on the injectors. But what level injectors do i need? 500cc or higher?
Chris
TEMS requires TEMS compatible struts. Such as ones from toyota or Tokico Illumina II's. It's basically a manually adjusted strut, but the cap that sits on top of it is an electronically controlled servo, hooked to the TEMS button in the cabin. Sport and Normal are the options, 2 settings. What it does is when you select Sport <or normal depending on what setting it's already at> it sends a signal to the servo's in the strut towers to turn a knob on top of the TEMS compatible struts. Struts and shock absorbers are basically the same thing in respects to what they do.
Not trying to tell you NOT to do it, just making sure you have all the information in front of you and you know the difference, or similarity in TEMS and coil-overs. The Supras equiped with TEMS came with the sport package. Had the headlight washer, LSD rear end, I believe different clutch packs as well. If you want to put a TEMS unit in your NON-TEMS Supra I'd suggest finding one in a junk yard or post a want to buy in the want to buy section here on the board and see how your luck goes!
