Old 09-14-2006, 05:55 PM   #1
sd88supra
sd88supra is on a distinguished road
looks like a maladjusted or bad throttle position sensor. check your error codes, you'll probably get a 41 or 51. 41 youll have to adjust it using a multimeter, 51 youll need a new one. very easy job to do. the TPS can make the world a difference. also make sure you dont have any air leaks.
sd88supra is offline   Reply With Quote
