Thread: Manifold gasket
Old 04-21-2005, 06:37 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
well... you're gonna need a 14mm spanner (wrench) and socket to undo the 3 turbo elbow bolts from the downpipe and the 4 bolts on the manifold, also a 17mm or 19mm can't quite remember... socket with universal/swivel to make it easy access and undo the oil feed to the turbo which is located on the block beside the oil pressure sender unit, once you take off the accordian hose/intake pipe you will see the bolt quite easily
also you will need a 12mm socket to undo the two nuts off the oil return pipe from the turbo to block
basically with all this there are only two gaskets... one for the oil return, one for the manifold... if you do replace the one on the block ensure you clean that surface real good.. if you don't or leave parts of the gasket there it will leak... alot lol
the original toyota hose clamps are 10mm... so get a socket and you'll get them undone fairly quick... don't forget to unplug the afm and pull off the vacuum line under the intake pipe going to the power steering pump
have fun and good luck
Pics of my build.
Do a diagnostic first!
