Thread: JZA 70 owners?
Old 06-28-2006, 10:26 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
get a jdm 2jz map sensor & install jdm 2jz injectors & get a walbro, then up the boost to 20psi
but if you wanna play with 20psi i highly recommend you get your turbos rebuild and steel wheels put in or you go max 16psi ish as the turbos aren't reknowned for hanging on at high boost levels
Pics of my build.
Do a diagnostic first!
