Old 06-13-2006, 02:42 AM   #19
mrnickleye
mrnickleye's Avatar
You could use sheet metal, but it does not insulate as well as plastic.
By box, I meant I boxed it in. I actually used a household trash can. I cut 2 pieces out of it, one for the top, and one for the side that is toward the radiator.
The bottom is already there, as is the fender side.
The back is best left open, as the AFM blocks enough off, and you need it open in the back to allow the outside air to flow better over the filter.
