Thread: 86.5 7mgte
Old 06-06-2006, 09:36 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the turbo pressure signal = you have a boost leak which is causing the bog
also you will more than likely find that the wire has broken off the knock sensor plug or has a short circuit, or is not plugged in at all
there are two knock sensors on the intake side of the block about #2 cyl & #5 cyl
pull the plugs off and inspect them
good luck
Pics of my build.
Do a diagnostic first!
