Old 06-01-2006, 04:58 PM   #2
Supra2NR
Supra2NR's Avatar
the afm was no problem at all, the wires will fit perfectly to its new position, no cuttin involved with this all you need is clamps to hold it in
the air duct has a coupler in the end and i used zip ties and i used the old harness where the old filter bolts on to as an anchor so it wont fall if i hit a bump or anything, but the hole on top of the filter is 2.5 inches and it secures pretty good with the step down coupler
the 45 degree coupler was used in the car b4 , the old owner maed a semi-cold air intake, which was not even good , nd i jusd used it when i was improvising my intake, you can find those at any good shops jus ask for it , cuz the shop that i go to can even custom fit me one in any color , but thats jus for looks for me and i will do that later on
hopefully i was any help to u and good luck
look at this pic thats the old setup that he did , its was pretty crappy cuz it wasnt even sealed, and god knows what got into the engine with his dumbass, but this is where i got the 45 deg. maybe if u look at the stock system u can salvage one from it too
