Old 06-01-2006, 01:29 PM   #4
Supra2NR
Supra2NR's Avatar
yo weezl this is thanx to you too i thinkis the final setup that i will use
sori for the pics (took it with a camera phone)
with this setup i also moved the afm, one good purpose is to free up some space in the front,
on the 1st pic
the red circle is a 2.75 to 3 inch coupler with a 45 degree bend
the blue lines is a 22 degree bend pipe from pepboys
cone filter from pepboys (i advice getting k&n filters, theyre better)
the green lines is a 2.5 to 3 inch coupler that i used to insert the duct that lead to the bottom front of the car
last one is a 3 inch plastic tubing pretty long actually it goes all the way down to the bottom slits in the front and i used some zip ties to anchor it to the bottom grill, if you are gonna do the duct too, u need to cut a hole in the plastic cover behind your fog light underneath the car
you dont need to disassemble your headlights either like S.O.G.I. said jus use the oblong shaped hole under the headlights, i think this is where the old inlet goes , so all this setup would coust u around 30 bucks pretty cheap for a cold air intake dunt u think?
Name:	final intake mod.JPG
ID:	258   Click image for larger version
