Old 03-16-2005, 11:20 PM   #1
hangsupra
well....when to go on first gear...if the idle below 2000 rpm then its kind of slow...like it didnt burn the gass enough or it soudns like back-fire right....and then after you go over 2000 rpm then its running smooth right...is that right...well if thats how it is than....it just that you need to adjust your air follow meter from the throttle body and the air flow metter (next to the air filters )...cause....it didnt flow right... try that first and see if it work....before i can tell you something else alright.... :P
