Old 05-07-2006, 11:03 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
there should be a small black single spade & a rather large eyelet cable that bolts/connects to the starter
both obviously connected since your starter is working
make sure your distributor is not off by a tooth
ensure you have connected the ignitor assembly properly
make sure you do have fuel in the tank
check to see if you have spark (pull a spark wire out, shove an old spark plug in and lean it close to some metal, go crank the car and see if it sparks)
to check if you have fuel coming up to the engine get a piece of wire or a paper clip and put one end in FP & the other end in B+ and turn the key to the on position (not cranking) and go listen to your engine and see if you can hear the fuel coming up
try these and let us know how you get on
Pics of my build.
Do a diagnostic first!
