Old 04-30-2006, 08:49 PM   #4
Burn N' Up
Burn N' Up's Avatar
Make sure your all three of you switches work, make sure you bulbs arn't burnt out, make sure the "dome" fuse is in place. If your door ones are working then the switch that activates the overhead is working as well, if everything else is working then the problem is "integration relay No. 1." Not sure where that it is but it is wired to your seat belt lights and basically every interior light you have. I don't know where it is, and based off of the hour long guess and check hunt I just had i'm gonna say you'll have to find it yourself. I can describe it though using the manual, should have 10 wires going to it, Green/white, Viloet/red, Gray/blue, Red, Red/yellow, Red/white, Red/green, Blue/black, white/black(i think), and a yellow. Good luck, i assume it's gonna be another little blue box near integration 2. Let us know if you find it.
