Old 04-23-2006, 11:56 PM   #2
mrnickleye
mrnickleye's Avatar
So anyway, the supra pedals are not normally stiff. You can spray some silicone at all the pivot points. You may want to pull the cable out and spray silicone down into it while pulling/pushing it, to work the lube into it.
Many times a cable get worn internally, and must be replaced. It should not be too expensive.
