Thread: LSD Non-Turbo?
Old 04-10-2006, 07:16 AM   #1
SCRAMJET
SCRAMJET's Avatar
In your engine bay on your compliance plate, there will be a part saying TRANS/AXLE. The first part stamped after that should read W58 which is the code for the standard NA transmission. The second code written there is the code for your diff. It is my understanding that if the number in the code for the axel is an odd number, it is an LSD diff. Mine was G285 which means it's an LSD diff. Mine used to be a non turbo also so you might be lucky and have one too.
