Old 03-26-2006, 05:32 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
>"And im hoping your not reusing the stock head bolts....."<
Bought a set of ARP bolts, not studs. Discovered that 10 of the 14 won't go into the head w/o grinding clearance into the bolt area. All 4 end bolts go in fine. So I used 4 of the ARP's and 10 stock bolts--all just torqued tonight to 72 ft. lb.
I really don't think the ARP bolts/studs solve anything. The stock bolts don't stretch (other than elastically just like the ARP's). The stock gasket crushes over time/heat and that's why the bolts get loose.
Anyone ever BREAK a stock bolt?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
