Old 03-05-2006, 08:07 PM   #2
Isphius
Isphius's Avatar
is there anything wrong with the stock n/a ecu and intake manifold for running small ammounts of boost? also what exactly is involved in using the lexus afm/550 injector mod? does it just make the computer think its flowing less air and fuel than it really is? but since the injectors are larger they flow more per signal pulse from the ecu...? i just want to run about 8 psi, nothing big. ill just get a stock toyota HG and arp bolts and torque it to the higher specs ive been reading about. they seem to be fine for stock turbos. and thats pretty much what id be doing. maybe even a garett supercharger if i can.
