Old 03-01-2006, 10:35 PM   #6
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
fuel cut all happens in the air flow meter
the airflow is changed to a frequency of hz
when the frequency hits about 1500hz fuel cut is introduced
so basically when a certain amount of airflow comes thru the afm tells the ecu and the ecu spits the dummy and throws on fuel cut
the only way to stop the ecu from laying on fuel cut is to trick it by telling the ecu there is less air getting in (i.e fuel cut defencer)
fcd's clamp the signal at about 13-1400hz and the ecu never knows how much air is really in there
which is why you have to be really really sure you have the fuel available to compensate what the ecu doesn't see
example
lexus and 550cc injectors
you put on a lexus afm and now your car is getting 25% more air but the ecu doesn't know it is... it sneaks in thru the side chamber
the stock ecu is still delivering fuel for the air it can only see thru the main chamber.... suddenly you are 25% short on fuel.... if you go wot on this you may very well damage your engine
so to fix this fueling problem you add 550cc injectors and it's all evened out again
also there is no fuel cut as the ecu doesn't see the 1400 or 1500hz ever again (till 25psi or so) as the extra air is sneaking thru the side (so it's another fcd of sorts)
lemme know if this needs further explaining
Pics of my build.
Do a diagnostic first!
