Old 02-28-2006, 01:34 AM   #11
hangsupra
first... is the light turns on on the brake.... light... on your cluster.. if so then double check on your brake fluid... or is it the lights come the voltage.... if it came out on the voltage or the battery then i pretty sure that your alternative if bad or poor... this is another thing that happen on my car tho.. the positive wired that connect on my alternater.. that by itself on the alternater.... its broke inside the wraper... it got strap or cut inside so there loosing the juice when i accelarated or when i roll on a bump road... so try to check on that one wired by itseft ontop of the alternater tho... hope this help....
