Old 01-08-2006, 04:51 PM   #1
94GT47Widebody
94GT47Widebody is on a distinguished road
I appologize..Let me explain better.
From the begining...
I was driving and noticed the car had less power and sounded different (misfiring)
On my way home I broke the cam belt tesnioner throwing the car out of time but still able to run enough to get me home. (one time its good to still have a stock block)
I replaced the tensioner with a billet one. put the car back in time and it ran again with the same lack of power and still sounding differnt.
I decided to put fresh fuel in the car (91octane) and take it for a spin (I know I need race fuel!)
while driving the car spit sputters and threw a bomb out the back end ran for a few seconds more and then died.
I towed the car back to my house and began to troubleshoot.... and now here is what I found.....
Number 4 plug electrode was melted away:
I replaced the nuber 4 plug only and gapped it according to what 1 2 3 were gapped. I tried to start the car and would not start.
At that point I decided to check spark:
Pulled #2 plug and coil pack (#2 is super easy to get to thats why)
It sparked..
Pulled number 1 plug and coil pack. No spark
I took plug from 1 and checked with number 2 coil pack on number 2 harness connection... I had spark.... good plug!
I then moved number 1 plug and number 1 coil pack to the number 2 harness connection and checked for spark..... I have spark!
These are the same symptoms for 1 3 4 5 6! Good plugs, Good coils.. no spark.
Basically I am only getting signal to the number 2 harness plug to initiate the spark.
All modifications were completed by Ryan Woon at WOTM. As of now I have no reason to doubt his desgn. His only recomendation to me was to run with race fuel as much as possible. Boost is as low as the controller will allow me to go.. roughly 16psi. Plugs are a 7 heat range NGK VPOWER
94GT47Widebody is offline   Reply With Quote
