Old 01-04-2006, 12:46 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by SKILMATIC
...The most wear an tear would occur on your bearings from improper oil use.
The most wear and tear would have occurred on the engine bearings of the Mkiv Supra you're planning to buy if it was ever run with an extremely low oil level, and/or if a very large shot of NO2 was installed and regularly used on the car. Suprafann, in addition to checking for other signs of poor maintenance, also be sure to check carefully for signs of NO2 installation (eg. a hole drilled, tapped & then plugged in the throttle body), as well as 'standard' bpu modifications, before you make your final offer to the seller.
Life begins at 30psi.
