Old 12-17-2005, 08:37 AM   #1
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
I doubt I could move the 3600lbs car while it has jack stands on the front, by turning the motor over, trying to torque the front crank bolt.
I thought that might be the trick.
As for the oil line, you're saying that I should remove it from the block? And then when I install, I should put the line on the turbo then reattach it to the block?
I bought a rebuilt head, and it has all the studs necessary to bolt everything backup. Whhheeewww.....
Bullz_EyE is offline   Reply With Quote
