Thread: plaese help
Old 11-07-2005, 08:52 PM   #1
nickvash0104
nickvash0104 is on a distinguished road
Throwing the Bar's in there only slows the inevitable. Hopefully you didn't have a trace of antifreeze in there - otherwise be prepared for a very quick clogging of your cooling system.
Of course, if this is your daily driver, you want to be as gentle with it as you can at this point - unless, like Bullz_EyE said, you're trying to finish the car off as quickly as you can.
Maybe you've got a compression loss in the cylinders, causing the massive loss of power.
I know that most of the people here will tell you that it's not a matter of if the head gasket will blow, but when. Once the symptoms start, everything you do to try and fix it might delay the problem, but never remedy it.
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
