Old 05-17-2015, 03:14 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Hey, welcome to the forum! I had an 87 auto Supra back in the day that did the same shifting yours is doing. My problem was a melted TPS, if code 51 is the AC switch/IDL circuit code then that also points to a TPS failure. If you have downshift problems, check out the kickdown cable adjustment and make sure its in spec. Good luck!
