Originally Posted by wildman103
I'm sorry I'm running an 88 Toyota but I now have spark but only in cylinders 2 and 5 but when I spin my CPS my injectors open, my problem before was a bad ecu but now I'm not sure I checked coil packs and their good all sets are doing the same thing I check continuity between ecu plugs and sensor plugs everything checks out both igniters have the same result so how do I test to see if it's an ecu problem or CPS any ideas would be great, also I cleaned all grounds and grounded coil packs, any help would be greatly appreciated
Troubleshooting the spark is right in the TSRM (engine). Have you followed those steps?
