04-27-2014, 03:07 AM
#1
Supra Owner
Originally Posted by wildman103
I'm sorry I'm running an 88 Toyota but I now have spark but only in cylinders 2 and 5 but when I spin my CPS my injectors open, my problem before was a bad ecu but now I'm not sure I checked coil packs and their good all sets are doing the same thing I check continuity between ecu plugs and sensor plugs everything checks out both igniters have the same result so how do I test to see if it's an ecu problem or CPS any ideas would be great, also I cleaned all grounds and grounded coil packs, any help would be greatly appreciated
Troubleshooting the spark is right in the TSRM (engine). Have you followed those steps?
Life begins at 30psi.
